Can a synthetic node be exported or downloaded to be recreated in a different network?
  • Nov 19, 2024 4:23 PM UTC
  • 235 views
I have created a synthetic node inside a workspace to run down the various connections for a complex multibranch setup with multiple MPLS vpns and Internet VPNs.
Is there a way to move or download the synthetic nodes so I can recreate them inside the parent network now that I have confirmed the accuracy inside the workspace?
Note that I am trying to move it from a workspace back to the parent network - otherwise I would just recreate the workspace from the parent and include the synthetic.
Best answer by RobertWelch
Export → Advanced Export  → Choose Devices.  Note that you’ll need at least one non-Synthetic Source.  Export the Parent Snapshot.  Then combine the Workspace and Parent Snapshot.
Try this on a new Network first to make sure it all works as planned.
  • Nov 19, 2024 4:29 PM UTC
  • Nov 19, 2024 5:08 PM UTC
OK, after looking for a bit the ‘Export’ is the 3 dots on the far left of the snapshot in question.
Will probably recreate manually instead of trying to do anything that can mess with our main network - far too large to risk.
Or, export your main Networks Snapshot.  Create a new Network and import the Snapshot.
  • Nov 19, 2024 5:32 PM UTC
Note that you can also use the API to extract synthetic nodes and then put add them to another network.
