NQE Updates for 25.2.0
Related products:NQE
  • March 11, 2025
  • 13 views
Release Date: February 13, 2025
We’re pleased to announce the latest enhancements to NQE as part of release 25.2.0.
For more details on platform-wide updates, see the full Forward Enterprise 25.2.0 Release Notes.
What’s New
  • any and all are now recognized as functions.
  • dataConnectors is now a field of Network.
  • lifecycleData is now a field of AclEntry.
Improvements
  • The osSupport field of Platform can now be present for the OS values:
    • CHECKPOINT
    • F5
    • FORTINET
Command Changes
Several command modifications have been made to improve accuracy and compatibility:
  • CHECKPOINT (INTERFACES command type) – In some cases, show interface {} has been replaced with show interfaces in the command output.
  • CHECKPOINT (VERSION command type) – In some cases, POST show-api-versions has been replaced with POST /web_api/show-api-versions in the command output.
  • JUNIPER_JUNOS, JUNIPER_SRX (VERSION command type) – In some cases, show version invoke-on other-routing-engine has been added to the command output.
  • NXOS (VRF_MCAST_ROUTING command type, ACI mode) – Added show ip mroute detail vrf all to the command output.
  • NETSCALER (SLB_GSLB_VIRTUAL_SERVERS command type) – In some cases, show gslb vserver {} has been replaced with show gslb vserver in the command output.
Deprecations
Certain fields and functions are now deprecated and will be removed in a future major release.
Deprecated Fields
(Fields newly deprecated in this release are marked with (new))
CloudAccount
  • publicUnallocatedIps
Cve
  • criteria
  • description
  • severity
Ethernet
  • negotiatedPortSpeed
ExternalSources
  • cliSources
  • httpSources (new)
  • snmpSources
System
  • uptimeSeconds
VpcData
  • cloudType
Deprecated Functions
The following built-in functions are deprecated and will be removed in a major release:
  • blockDiff_alpha1
  • blockMatches_alpha1
  • hasBlockMatch_alpha1
For each function, use the equivalent function without the _alpha1 suffix instead.
