NQE Updates for 25.10.0
Related products:NQE
  • October 30, 2025
  • 41 views
Released: 2025-10-21
We are happy to announce the following enhancements to NQE as part of release 25.10.0.
See the full release notes for Forward Enterprise version 25.10.0.
What’s New
  • Queries can now include an @primaryKey annotation in the main expression to define a primary key, making it easier to identify unique records in query results.
  • The HeaderRegion type now includes a new domains field.
  • AVAYA_ERS has been added as a value of the OS type, expanding support for Avaya devices.
What’s Fixed
  • The IfaceType type now includes IF_BRIDGE. Switched virtual interfaces (SVIs) on devices running NXOS now correctly report interfaceType = IF_BRIDGE in the Iface data model.
  • The Platform.osVersion field is now populated for F5 devices when the version follows the format 1.5.1-12283 and the operating system is F5OS. Because NQE does not yet define a dedicated OS value for F5OS, these devices currently use OS = UNKNOWN.
  • Pretty printing now works correctly in more cases, including expressions with binary operators, when clauses, and parentheses.
Command Changes
  • Huawei – Added Command definitions for the HUAWEI operating system in the Outputs of each Device.
  • Juniper SRX – For CommandType = DNS_CACHE, the command now includes show host routing-instance {} {} in device outputs.
  • F5 – For CommandType = CONFIG, new commands were added to improve visibility into SIP and HTTP/2 configurations:
    • list ltm message-routing sip profile router
    • list ltm message-routing sip profile session
    • list ltm profile http2
  • Aruba AOS-CX
    • For CommandType = BGP_PEERS, the command show bgp ip unicast neighbors has been replaced with show bgp ipv4 unicast neighbors.
    • For CommandType = BGP_SUMMARY, the command show bgp ip unicast summary has been replaced with show bgp ipv4 unicast summary.
Deprecations
The following fields, functions, and types are deprecated and will be removed in a future major release.
Fields
  • CloudAccountpublicUnallocatedIps
  • Cvecriteria, description, severity
  • EthernetnegotiatedPortSpeed
  • ExternalSourcescliSources, httpSources, snmpSources
  • SystemuptimeSeconds
  • VpcDatacloudType
Functions
  • The built-in functions blockDiff_alpha1, blockMatches_alpha1, and hasBlockMatch_alpha1 are deprecated.
    Use the versions without the _alpha1 suffix instead.
Types
Number (new) – The Number type is deprecated and replaced by Integer.
During pretty printing, any instance of Number is automatically converted to Integer, and a warning is issued for each use.
