NQE Updates for 25.1.0
Related products:NQE
  • January 28, 2025
  • 17 views
Released: 2025-01-21
We are happy to announce the following enhancements to NQE as part of release 25.1.0.
See also the full release notes for Forward Enterprise version 25.1.0.
What’s New
  • endpoints of type NetworkEndpoint is now a field of Network.
  • peerDeviceName and peerVrf are now fields of BgpNeighbor.
  • isIPv4 is now a function.
  • isIPv6 is now a function.
  • The fromTo function now has an overload that accepts two values of type IpAddress.
  • A value of type IpAddress can be inverted via -.
Improvements
  • The field uptime of System is now populated for the OS value ARUBA_CX_SWITCH.
  • The Command with CommandType value CONFIG was modified for the OS value F5 by adding 13 additional commands among various cases in the Outputs of a Device.
  • The Command with CommandType value F5_AFM_CONFIG was modified for the OS value F5 by adding 3 additional commands among various cases in the Outputs of a Device.
Deprecations
Some fields and functions are deprecated and will be removed in a future major release.
Fields
  • CloudAccount:
    • publicUnallocatedIps
  • Cve:
    • criteria
    • description
    • severity
  • Ethernet:
    • negotiatedPortSpeed
  • ExternalSources:
    • cliSources
    • snmpSources
  • System:
    • uptimeSeconds
  • VpcData:
    • cloudType
Functions
  • The built-in functions blockDiff_alpha1, blockMatches_alpha1, and hasBlockMatch_alpha1 are deprecated. They will be removed in a major release. For each function, use the version without the _alpha1 suffix instead.
