NQE Updates for 24.8.0
Related products:NQE
  • September 9, 2024
  • 26 views
Released: 2024-08-22
We are happy to announce the following enhancements to NQE as part of release 24.8.0.
See the full NQE release notes for Forward Enterprise version 24.8.0.
Breaking Change Preannouncements
  • Vendor Value Deprecation: The value OPENFLOW_GENERIC for Vendor is deprecated and will be removed in release 24.9.
  • OS and Vendor Deprecation: The value NETRONOME_OVS_OFCTL for OS and the value NETRONOME for Vendor are deprecated and will be removed in release 24.9.
What’s New
  • New VLAN Field: VLAN information is now included as a field of Device. This enhancement allows you to query VLAN details more efficiently.
  • Ethernet Speed Field Update: A new field, speedMbps, has been added to Ethernet. This field can express speeds from aggregated interfaces. The previous field negotiatedPortSpeed of Ethernet is now deprecated.
  • DELL SONIC Support: The value DELL_SONIC is now recognized as a possible value for OS.
  • General Dynamics and Viasat Support: The values GENERAL_DYNAMICS for Vendor and GENERAL_DYNAMICS_ENCRYPTOR for OS have been added. Additionally, VIASAT_ENCRYPTOR is now a possible value for OS.
Improvements
  • Netscaler Hostname Command: A command with CommandType value HOSTNAME now exists for the OS value NETSCALER in the Outputs of a Device.
  • Netscaler SLB Command Modifications: Several SLB (Server Load Balancing) commands have been modified for NETSCALER:
    • SLB_CS_VIRTUAL_SERVERS now uses show cs vserver.
    • SLB_SERVICE_GROUPS now uses show serviceGroup -includeMembers.
    • SLB_VIRTUAL_SERVERS now uses show lb vserver.
  • Checkpoint Uptime Command: The command with CommandType value UPTIME for CHECKPOINT has been updated in some cases to use uptime -p.
Deprecations
  • VpcData CloudType Field: The field cloudType on the record VpcData is deprecated and will be removed in a future release. Use the cloudType field on the record CloudAccount instead.
  • Built-in Function Deprecations: The built-in functions blockDiff_alpha1, blockMatches_alpha1, and hasBlockMatch_alpha1 are deprecated and will be removed in a future release. Use the corresponding function without the _alpha1 suffix.
  • Ethernet Port Speed Field: The field negotiatedPortSpeed of Ethernet is deprecated and will be removed in a future release. Use the new speedMbps field instead.
