Using NQE to Ensure Explicit Deny is the Final Statement on Cisco ACLs
  • Aug 27, 2025 4:43 PM UTC
  • 133 views
AricaFN
This NQE extracts the config for each ACL, accounting for all syntaxes used in Cisco devices. The order is determined by the line number, which is used to compare the line of the deny statement with the last line of the ACL config and returns the failures by device and ACL name.
standard(config) =
foreach match in patternMatches(config, `access-list {aclName:string} {!"remark"}`)
group match.line as config by match.data.aclName as name
select { name, config };
nested(config) =
foreach match
in patternMatches(config, `ip access-list {string} {name:string}`)
let config = (foreach line in match.line.children where !hasMatch(line.text, re`.*remark.*`) select line)
select { name: match.data.name, config };
foreach acl in standard(device.files.config) + nested(device.files.config)
let maxLine = max(foreach line in acl.config
select line.lineNumber)
where hasMatch(line.text, re`.*deny\s*ip any any.*`) &&
line.lineNumber < maxLine
select { device: device.name, acl: acl.name }
This expands on the NQE in Evaluating ACL rules from configuration to find last entry, where I referenced the method for grouping standard ACL config lines.
  • Aug 27, 2025 5:22 PM UTC
​@AricaFN can we filter this down to just Cisco devices for others to reuse
AricaFN
  • Sep 16, 2025 4:58 PM UTC
​@GaryB
standard(config) =
nested(config) =
foreach match
