​​Understanding Forward NQE’s _lookup Optimization
  • Aug 18, 2025 2:45 PM UTC
  • Aug 20, 2025 8:33 PM UTC
  • 116 views
rob
Forward NQE includes several under-the-hood optimizations that can improve query performance. This post focuses on the _lookup optimization, which can reduce execution time when filtering on a single key field using an exact equality comparison. Leveraging _lookup is considered a best practice whenever possible.
In a recent query I wrote joining device CVE information with the EPSS database in a network containing 10,000 devices, re-writing the NQE to take advantage of _lookup reduced the execution time by over 50%. While this kind of optimization isn’t as dramatic as parallelization—where a multi-minute query might drop to seconds—it can still offer a significant and worthwhile improvement, particularly in queries with repeated key-based lookups over large lists.
What _lookup Does
Normally, when you write a loop in NQE that scans a list for a match, the query engine will iterate over every item in that list and check the condition. This can be slow if the list or number of devices in the network is large.
When a query uses a foreach on a list of records followed by a where clause that filters that list using an exact equality comparison on a single field, NQE may rewrite the loop into a _lookup operation. This changes the behavior from scanning the entire list for each match to performing a direct, indexed lookup.
 The index used for this optimization comes from two possible sources:
  • Data model lists that already have a predefined index on that field (key fields are not exposed in the UI).
  • User-defined lists that are saved to a variable and iterated over more than once by that same field, in which case NQE will automatically build an index.
Building the index requires one initial pass over the list (O(n)), but all subsequent accesses are O(1). This makes repeated key-based lookups significantly faster, especially when the list is large or the same field is queried multiple times.
How to Tell If _lookup Is Happening
You can see whether _lookup is being used by looking at the Query Debug Panel by holding either alt(windows) or option(mac) and left clicking on Execute from the NQE IDE. If you see _lookup(...) in the Query Debug Panel, the optimization is being leveraged for that section of the query.
AD_4nXdVnzL4a7qzloEPHdacOwdqITj4_Y4Grzcm7pPfUGfrDF_bRBv5A75j1Vi6K2GMUCxERz4BpoB-k9LSFYs-lAp7VMsBT1ErP4PXIFl1_uKTf1wi-1ZDaFn4HtOj5NK3Gq13YGCGQA?key=6ajxsR9OTrrxDOCbMpbbog
The Query Debug Panel also displays useful details such as execution duration, allowing you to see the exact NQE run time and compare how different changes to the query impact performance.
If you don’t see _lookup, then the engine is performing a full scan.
Simple Example: No _lookup Optimization
Using a function like matches() or any non-exact match breaks the optimization:
Syntax
where matches(interface.name, "ge-0/0/0")
select { device: device.name, interface: interface.name }
AD_4nXcJ9K8yusCUakmhR-RANF9QluMBAdSzWjR212uvJDF1fUjakph0xOBB_IEMg-Aj4uYsbItGCKDMjGB8mUd1yHtTFh4jHrteMLzTzbgbgvnJkDCr7mLcd5A9hv1cHmG-W3Koj55ovA?key=6ajxsR9OTrrxDOCbMpbbogAD_4nXferTKBMTDBliEHEUonUGix9ko8fx5viYe9QDxKR4v3Y7xQzr1PbAxKBxt9N-XIbtqfRwREG6sMsdBr6REmGQ1P1vl3pMIPSR6fBzSTKjR7sXIxyEoerIFupWmzUyvFAT4-i-_m?key=6ajxsR9OTrrxDOCbMpbbog
Query Debug Panel
_lookup does not exist in the below syntax, indicating that the optimization is not being leveraged.
@juniper(INDENTATION);
parallel_foreach device in network.devices
⟪foreach interface in ⟪device.interfaces⟫
 where @builtin/matches(interface.name, "ge-0/0/0")
 select ⟪{ device: ⟪⟪device⟫.name⟫, interface: ⟪⟪interface⟫.name⟫ }⟫⟫
AD_4nXc9NTXj4WF9gEzajyXzm-o9zeMJXunTyJJu5d8mQBaoJcs1r0706M0WwdG6o0VpZg3I1Kr5-k-b1fyhu2OGneu5cnrvYCBpKNPykMve9oAO6g_NTRYXjqkWOgiXinXvF51ihCHV?key=6ajxsR9OTrrxDOCbMpbbogAD_4nXel_N4twTekdy4IPc6ezQvfFjanLa4iV9cyGRIYkqC4lc4oeJiwBjU6d7HHmXs5jYvi68TfHhUiQmvg6vZAWJqF9Gr0IxI2nOTK0Gb2Mva5kEB0c2VWAC-iCcVzM_SgrE6DqtzvoQ?key=6ajxsR9OTrrxDOCbMpbbog
Simple Example: _lookup Optimization Enabled
Switching to a simple equality check on a unique key enables _lookup:
Query
where interface.name == "ge-0/0/0"
AD_4nXe_Qy2p7_hbTr7aWCTwqcLbmY1EW-z0QD6sQDtR2UXkvqC4C_aikojs_YBB07ygRBGf9ToUajQg2wJY0ASSFWNhJGdzfkG0izqt1T5L88zU61kuOZZ_trOGh19zxTmBMnjZtlyi_g?key=6ajxsR9OTrrxDOCbMpbbogAD_4nXfsgijl0jziDXzOAt_Po438eCmhVqsrw94NgTy2aRkwRUvN7HxIOhKmd5tiHX8KSczK5aATDr5jRJ2xyDHE63Al_lDovXe0Mz9crLJkzv2ThIy-MdNmbTE_bRlRDKHp56mrthnYPQ?key=6ajxsR9OTrrxDOCbMpbbog
Query Debug Panel
⟪foreach interface in _lookup(device.interfaces, "name", "ge-0/0/0")
AD_4nXcvIXNOx58ieB38gK5v_YqUr1lm_xZXbMYrfaWSvZLda3vclQ7fX5ocIwbSZf2SA08jtWNxDfANZ84NccwDPxAoOW3PtpzgqLwe9_ySRS7_xKqMPCpX5a5GMWtTbzuidhAS9XOdgA?key=6ajxsR9OTrrxDOCbMpbbogAD_4nXe01dVkLoo0J9OyO8CSDx1ILcSGtW6-0SDe9Bdy_Miz6zBmaj_ntBkkuf9sMWJcyiX74JDADWVZOS0c5d6EFP7b-eWdb_5QHG9ZEr68-SWVm-GNqUI9ge0sm0-i-sAARGbQmndl?key=6ajxsR9OTrrxDOCbMpbbog
Here, _lookup means the engine jumps directly to the matching interface instead of scanning all interfaces.
Advanced Example: _lookup Optimization in Larger Queries
The _lookup optimization isn’t just for simple interface-name matches — it also applies in larger, more complex queries when you’re joining one dataset to another via a unique key using ==. In fact, it can make a huge difference in scenarios where you’re performing the same lookup for many records.
Here’s an example using EPSS data which is a list
Optimized Version (with _lookup)
EPSS = network.externalSources.first_org.ePSS_LATEST;
foreach cveFinding in device.cveFindings
let epssRecord = max(foreach epssRecord in EPSS
                     where epssRecord.cve == cveFinding.cveId
                     select epssRecord)
  cveFindingCveId: cveFinding.cveId,
  isVulnerable: cveFinding.isVulnerable,
  basis: cveFinding.basis,
  "EPSS Score": epssRecord?.epss,
  "EPSS Percentile": epssRecord?.percentile,
  "EPSS Date": epssRecord?.date
AD_4nXeOPxfV5j9CPdaqEgEX7BzjYjCxximheTCgipPX9Z-TSHhQkcNvclHsWmYhVbOG2xLc0yIp6hTL4-WL9yeiFsFYG7JBK-NrPnaSo8ycaA3MvQQpo1j1RHTbhRCfRMGF89mOxLx6eQ?key=6ajxsR9OTrrxDOCbMpbbogAD_4nXeEkVBHhNH4IMldj4PCIaGZdqfM3TfeWjpgpLziYPPVHJ5Tzknbvi0_dgnYqc1lyl_rl-k1iC1yDVGjnsnVNL_I6ext6jt1TQNl7xxo5HlNUGH7VcjP6nawVpdcZdzVjvqeZoCnlw?key=6ajxsR9OTrrxDOCbMpbbog
Query Debug Panel
⟪foreach cveFinding in ⟪device.cveFindings⟫
 let epssRecord = @builtin/max(
   foreach epssRecord
     in _lookup(./EPSS, "cve", cveFinding.cveId)
   select epssRecord)
 select { ... }
AD_4nXeaGskADVrNTN-YJfHoqoWab-vhmwaqclWG2_cZP9M021REQcRNyVXKhOD1YI1nxucR7fkCqlSlhWjuaqYSC1skYYm2_43CS2C1nr1cPN9Uc8fr2At_6jtbc49MNa8aCSLARRzm4w?key=6ajxsR9OTrrxDOCbMpbbogAD_4nXc3OUbpn8y-9Mc56-J7fjp1x_5LyhnK-tTUXhzSUQExm0qmRzE-CvrkurS0YqhwcnW43rECjtJcI0SB6zo2tNv_catSKmonSxo4TztHsEODhFQEw-F-A_Y9M9nYdnY_QqaI62Rfsw?key=6ajxsR9OTrrxDOCbMpbbog
Not Optimized
If you wrap the same logic in a function:
getEPSSRecord(cveId) =
where epssRecord.cve == cveId
select epssRecord);
let epssRecord = getEPSSRecord(cveFinding.cveId)
AD_4nXeeNVm8jSmd-o27Xati5Fr9pWc2x3GRUg1EbLOkOWkjlCl4iUdH-taIHGeFiNUDOr8m0anoNyIeRF-qAB37y1HwASglqil8gB0M75xKXK1o7UPZP5KQdNpYSnibSNd1r2GXR0UCLQ?key=6ajxsR9OTrrxDOCbMpbbogAD_4nXcggXilbQsw4ui6D44M3K9o14RA6aNJSLJhfLTFJrP2tyjBsMo94uvyB_bzxaMPDkFERq384IT6M5tvGkvHrSbMEj3Q-KNYDkE3Ugc_M395WE6c_ZWe-yq9PmWSWL-Y25xPhJgOzg?key=6ajxsR9OTrrxDOCbMpbbog
There is no _lookup optimization — even though the logic is the same as the inline version. The optimizer is conservative and when the lookup logic is wrapped in a separate function, the optimizer can’t verify there’s no other logic or side effects, so it won’t rewrite it to a _lookup.
Query Debug Panel
 let epssRecord = ./getEPSSRecord(cveFinding.cveId)
 select { ... }
Special Cases and Current Limitations
There are two important nuances to keep in mind when working with lookup optimization:
  1.     Data model collections inside function
    • When you filter a data-model collection (like network.devices) using a unique key with ==, lookup optimization does apply — even inside a function.
lookupDataModel(deviceName) =
where device.name == deviceName
select device.platform.vendor;
Debug output confirms this is rewritten into _lookup(...) even though the logic is wrapped in a function.
  1. User-defined collections inside functions
    • When filtering a user-defined list, optimization only applies if NQE can prove the collection is searched multiple times.
    • If the search is inline, the optimizer sees the repeated use and rewrites it
let result=foreach item in manualIndex
where item.key == "one"
select item.val
    becomes _lookup(manualIndex, "key", "one") in debug.
But if you hide this logic inside a function, the optimizer generally cannot detect the multiple searches, so it stays as a plain loop.
This means:
  • Data model collections → safe to wrap in helper functions
  • User-defined lists → best inlined if you want lookup optimization to apply.
Practical Implications
  • In the optimized version, each CVE lookup is an O(1) key access into the EPSS list.
  • In the non-optimized version, each lookup scans the entire EPSS list, making it O(n) per finding.
  • On large datasets (e.g., hundreds of thousands of EPSS records × thousands of device findings), this difference can mean minutes of runtime saved.
Best Practice Takeaways
 Inline the loop when possible if you want _lookup optimization.
  1. When using user-defined lists, inline equality checks if you want lookup optimization to apply — wrapping in helper functions may prevent the rewrite.
  2. For data model collections, lookup optimization works inside function.
  3. Always check your debug output for _lookup when performance matters.
  4. Use exact equality on unique keys (==) to trigger the optimization — no regex or pattern match.
