Prevent Outages from Uncommitted Configs: Using NQE to Compare Cisco Running and Startup Configs
  • Aug 25, 2025 1:15 PM UTC
  • Nov 24, 2025 11:42 PM UTC
  • 186 views
AricaFN
In dynamic network environments, engineers often make quick changes directly to a device’s running configuration to resolve issues or apply updates. But if those changes aren’t saved to the startup configuration, they’ll be lost on the next device restart—potentially causing outages or security gaps.
This oversight can lead to:
  • Devices booting with outdated configurations
  • Outages and service disruptions
  • Security vulnerabilities if critical policy changes aren’t retained
Manually verifying that all running configs are saved can be time-consuming and error-prone, especially in large environments. Forward Networks’ Network Query Engine (NQE) simplifies this process by automatically comparing the running and startup configurations across devices in your network.
Prerequisites
  • Access to Forward Enterprise with NQE enabled
  • Cisco devices modeled in Forward Networks
  • Network Admin role to create custom commands
  • Add the following Custom Commands (requires Network Admin Role)
    • show startup-config
    • show running-config
Documentation: NQE Overview
How the Query Works
This NQE query:
  • Leverages native Cisco commands to compare the running and startup configurations
  • Retrieves the system-reported differences between the two configs
  • Filters out noise and non-actionable differences to highlight only meaningful configuration changes
This approach allows you to quickly pinpoint devices where changes have not been saved, enabling proactive remediation.
Step-by-Step: Check for Unsaved Changes
Step 1: Open NQE
Go to Analyze → Network Query Engine in Forward Enterprise.
Step 2: Add a New Query
Paste the following NQE script into a new query:
exceptionsList = [
"Current Configuration ...",
"boot system.*"
exceptions(line) =
foreach item in exceptionsList
where hasMatch(line, regex(item))
select line;
flatten(outer) =
foreach list in outer
foreach item in list
select item;
config(device, show) =
where command.commandText == show
let response = parseConfigBlocks(device.platform.os, command.response)
let text = (foreach line in response
let lines = if length(line.children) == 0
then [line.text]
else [line.text] + flatten(foreach line1 in line.children
select if length(line1.children) == 0
then [line1.text]
else [line1.text] + flatten(foreach line2 in line1.children
select if length(line2.children) == 0
then [line2.text]
else [line2.text] + flatten(foreach line3 in line2.children
select if length(line3.children) == 0
then [line3.text]
else [line3.text] + flatten(foreach line4 in line3.children
select if length(line4.children) == 0
then [line4.text]
else [""]))))
foreach item in lines
where item not in exceptions(item)
select item)
foreach line in text
select line
let runningConfig = config(device, "show running-config")
let startupConfig = config(device, "show startup-config")
let uncommitted = runningConfig - startupConfig
let removed = startupConfig - runningConfig
violation: runningConfig != startupConfig,
os: device.platform.os,
uncommitted,
removed
This query checks for differences between the two configurations and adds a clear status label.
Step 3: Review the Results
The results table shows:
  • Device name
  • Violation on devices where config files don’t match
  • Lines that are uncommitted to or removed from the startup-config
Focus on failing devices to prioritize saving critical updates.
What’s Next?
This same method can be extended to:
  • Audit configuration consistency across other vendors, provided they offer similar commands that can be collected, parsed, and reported on
  • Check for specific unsaved critical changes (e.g., ACLs, SNMP settings)
  • Integrate with workflows to automate notifications to network teams
Why It Matters
Failing to commit configuration changes is an oversight that can have major consequences. With Forward Networks and NQE, you can proactively detect unsaved changes across your Cisco devices—reducing risk of:
  • Service outages after device reboots
  • Security policy rollbacks
  • Lengthy troubleshooting due to “mysterious” config reversion
By catching these issues early, your team can ensure configuration changes are properly committed and your network remains stable and predictable.
Questions? Ask below!
