NQE query to filter CVEs with CRITICAL Severity
  • Mar 25, 2024 4:12 PM UTC
  • 5 replies
  • 326 views
Hi,
I wrote an NQE query which is expected to return devices with CRITICAL severity only. The query returns almost a million results which is unlikely. Each device has so many rows with CRITICAL CVEs.
foreach cveDatabase in [network.cveDatabase]
foreach cve in cveDatabase.cves
let Severity = Severity.CRITICAL
  "Device Name": device.name,
  "CVE ID": cve.cveId,
  "Severity": Severity.CRITICAL,
  "Vendor": platform.vendor,
  "Model": platform.model
Best answer by Andreas
Hi @Steffi ,
Yes, you are correct about this output. I think this query does not do what you wanted it to do.
There are two problems.
The first problem is that in your query, you are listing every CVE in the database on every device, whether or not that CVE is relevant to the device and whether or not the CVE impacts the device. In effect, you are taking the “cross-product” of all CVEs in the database with all devices.
I think what you wanted was is to show critical CVEs that are relevant to each device. You can find that under device.cveFindings field. Specifically, you can add the lines “foreach finding in device.cveFindings
where finding.cveId == cve.cveId” to the query, so that each row shows a device and CVE that is relevant to it:
If you also wanted to only include rows for a device-CVE combination when the device is actually vulnerable to the CVE, then also add one “where finding.isVulnerable” to your query:
The second problem is that you probably want to filter to CVEs that are CRITICAL severity. To do that, you need to add “where cve.severity == Severity.CRITICAL” to your query. You can do that close to the top, as soon as you iterate over the cveDatabase:
This query should have one row per device-CVE combination where the device is vulnerable to the CVE and the CVE has CRITICAL severity.
  • Mar 25, 2024 4:39 PM UTC
Hi @Steffi ,
  • Mar 27, 2024 9:15 PM UTC
Hi @Andreas
Is it possible to get the CVE published date as a column in the output?
  • Mar 28, 2024 5:16 PM UTC
Hi @Steffi . Currently, the published date is not part of the NQE data model, so it is not accessible to any queries.
davetee
Community Manager
  • Community Manager
  • Mar 28, 2024 5:21 PM UTC
@Steffi - I’ll DM you for specifics on your use case and share those with our product team.
  • Mar 28, 2024 6:27 PM UTC
Thank you @andreas for your response!
I would like to put in a feature request for this if possible.
