NQE Query - Seeing multiple Values for single devices.
  • Mar 19, 2025 1:28 PM UTC
  • 102 views
Team ,
we are using belong NQE to get the information about Fortinet Firewall SNMP config and server white list information , however NQE provide the result , but devices are repeating ,ex, 1 devices we can see approx. 44 entry ,
can you please have a look on this and help us to fix .
NQE Query
// Patterns to match
pattern_community= ```
config system snmp community
    edit {string}
        set name {community:string}
        config hosts
            edit {string}
                set ip {ip:string} {netmask:string}
            next
where command.commandType == CommandType.CUSTOM
where command.commandText == "show system snmp community"
let central_mgmt = parseConfigBlocks(OS.FORTINET, command.response)
// Search for the ""pattern_fmg" pattern looking for a match
foreach match in blockMatches(central_mgmt, pattern_community)
//loop through the all server-address IP's and store them in variable "servers"
let servers = (foreach server in blockMatches(central_mgmt, pattern_community)
                  where server.data.ip == server.data.ip
                  select server.data.ip)
where !matches(device.name, "*_*")
// Produce the results
  "Device Name":      device.name,
  "Server 2":        servers
  • Mar 19, 2025 2:27 PM UTC
Hi ​@Rohit_809 Kumar ,
I think you can get rid of the duplicate rows by removing the “foreach match in blockMatches(central_mgmt, pattern_community)” line in your query.
