NQE example similar to using grep and awk
  • Jun 6, 2024 4:43 PM UTC
  • 7 replies
  • 265 views
RonAvila
when going through devices with interface descriptions, for example
description “to site x interface gi0/0”;
description “to site y interfaace gi0/1”:
block pattern is
description {desc:string}
Since it is a description with multiple words and space delimited, is there a way to get the entire description no matter how many words there are?  As the above would only get the first word.
similar to the way I would use grep for example:
grep '^description' ciscoconfig.txt
or if I wanted specific columns or text within lines beginning with description, I would grep and use awk like below
grep '^description' ciscoconfig.txt | awk '{print $2}'
grep '^description' ciscoconfig.txt | awk '{print $2 $4}'
grep '^description' ciscoconfig.txt | awk '{print $4 $2}'
Etc.
can anybody provide an NQE Example, Thanks
  • Jun 6, 2024 5:23 PM UTC
Hello @RonAvila
You can capture the entire string into a list
interface {string}
description {desc: (string*)}
  • Jun 6, 2024 5:52 PM UTC
Hi Ron,
I’m not sure if this is exactly what you’re looking for: But this will give you the output of:
Hostname ---- Interface ----- Description
I narrowed it down to just Cisco/IOS-XE with the “wheres” but you can adjust.
interface {IntName:string}
description {desc: ((string)*)}
let parsed = parseConfigBlocks(OS.IOS_XE , command.response)
foreach match in blockMatches(parsed, pattern)
select {Hostname:device.name , Intf:match.data.IntName, Desc:match.data.desc}
Hello @RonAvila
interface {string}
You beat me!
RonAvila
  • Jun 6, 2024 7:30 PM UTC
Thanks all!
RonAvila
  • Jun 10, 2024 5:32 PM UTC
Now is it possible to parse through the strings by character? For example, if I wanted to extract site_a, site_b from each of the descriptions? I want to extract just one piece of the description for each interface. Can we iterate through strings?
  • Jun 10, 2024 6:08 PM UTC
@RonAvila String manipulation requires a little special handling, We will be improving this in future releases. But here is one example.
test = """
interface Ethernet1/1
interface Ethernet1/2
description “to site y interface gi0/1”:
trimLast(s) = prefix(s, length(s)-1);
trimFirstLast(s) = max(foreach x in [0] let p = prefix(s, length(s)-2) select suffix(p, length(p)-1));
description {s: (string*)}
stringParse = `to site {site: string} interface {int: string}`;
let blocks = parseConfigBlocks(OS.UNKNOWN, test)
foreach match in blockMatches(blocks, pattern)
let newString = trimFirstLast(join(" ", match.data.s))
let site = patternMatch(newString, stringParse)
select {FromInterface: match.data.IntName, ToSite: site.site, ToInterface: site.int, }
RonAvila
  • Jun 10, 2024 6:39 PM UTC
Thanks @GaryB ! We will try this example!
