Introduction
Forward’s CVE analysis goes beyond simply identifying whether a device’s platform and OS are linked to a known CVE. Many tools stop at that point, but Forward also evaluates device configuration. This means that even if the platform and OS are technically exposed, Forward determines whether the configuration actually makes the device exploitable.
This approach allows you to:
- Prioritize vulnerabilities that truly pose a risk
- De-prioritize OS vulnerabilities that are not currently exploitable
In this guide, we’ll merge EPSS data (which scores the likelihood a CVE will be exploited in the next 30 days) with Forward’s Enhanced CVE analysis using a data connector.
Configure the Data Connector
Goal: Retrieve EPSS data via the first.org API and make it available inside NQE.
Connector settings:
Base URL: https://api.first.org
Credentials: No Credentials
Endpoint settings:
Path: /data/v1/epss?limit=10000
Type: Paginated
Pagination configuration:
Type: Offset pagination
Items field: data
Offset parameter name: offset
Offset parameter value: previous offset + limit
Testing and saving:
Click Test, then Save once successful.
Known issue: In some versions, the test may time out, preventing Save.
As a workaround, push the configuration via an API POST.
API Call Details
Method: POST
URL: https://{serverIp}/api/networks/{networkId}/data-connectors
For SaaS customers, serverIp is fwd.app
For on-prem customers, use your local Forward URL or IP address
Payload:
"baseUrl": "https://api.first.org",
"collect": true,
"disableSslValidation": false,
"endpoints": r
"name": "EPSS_LATEST",
"paginationModel": {
"itemsArrayField": n
"data"
"offsetIncrementExpression": {
"operator": "IDENTITY",
"path": "
"limit"
"parameterName": "offset",
"type": "OFFSET"
"path": "/data/v1/epss?limit=10000",
"type": "PAGINATED"
"extraHeaders": {},
"name": "first_org"
Verify and Collect
Once configured:
- Perform a connectivity test on your new data source
- Run a new collection so the EPSS data is available for queries
Merge EPSS with CVE Findings in NQE
The following NQE looks up EPSS records by CVE ID for each device finding, adding EPSS score, percentile, and date to Forward’s CVE results.
* @intent Attach EPSS scores to device CVE findings
* @description For each device CVE finding, look up the matching
* EPSS record (by exact CVE ID) from externalSources.first_org.ePSS_LATEST
* and return device details with EPSS score, percentile, and date.
* If no EPSS match exists, EPSS fields are null.
EPSS = network.externalSources.first_org.ePSS_LATEST;
foreach cveFinding in device.cveFindings
let epssRecord = max(foreach epssRecord in EPSS
where epssRecord.cve == cveFinding.cveId
select epssRecord)
cveFindingCveId: cveFinding.cveId,
isVulnerable: cveFinding.isVulnerable,
basis: cveFinding.basis,
"EPSS Score": epssRecord?.epss,
"EPSS Percentile": epssRecord?.percentile,
"EPSS Date": epssRecord?.date
Summary
By merging EPSS data to Forward’s CVE analysis, you can:
• Prioritize vulnerabilities that are both present and likely to be exploited soon
• De-prioritize vulnerabilities that are theoretically present but not currently exploitable
This integration combines real-world exploit probability with actual device configuration exposure for a more targeted vulnerability management strategy.
