Inventory device state from Description field
  • Sep 12, 2023 3:24 AM UTC
  • 139 views
Lane
I am trying to use the harvest the INVENTORY device state file but target the Description field, but I am unsure on on how to do that so that I can select it. I have the following:
import "External/Juniper-EoS";
where device.platform.vendor == Vendor.JUNIPER
let outputs=device.outputs
where command.commandType == CommandType.INVENTORY
where isPresent(platform.model)
foreach part in platform.components
where isPresent(part.serialNumber)
model: platform.model,
part: part.serialNumber,
violation: if part.partId in juniper_eos then true else false
Best answer by andrewcarver
Below would help in matching against a list of known end of life HW part numbers within the inventory. In approvedDescriptions [“THIS WILL BE THE LIST TO MATCH AGAINST”];
approvedDescriptions = [
"foo",
"bar"
let serialNumber = part.serialNumber
where isPresent(serialNumber)
foreach configLine in parseConfigBlocks(OS.UNKNOWN, command.response)
let text = configLine.text
where matches(text, "*" + serialNumber + "*")
let description = replaceMatches(text, "*" + serialNumber, "")
violation: description in approvedDescriptions,
Model: platform.model,
"Serial Number": part.serialNumber,
Description: description
  • Sep 19, 2023 12:27 AM UTC
"foo",
"bar"
