Interface Errors and/or High utilization verification
  • Oct 28, 2024 5:56 AM UTC
  • 123 views
I am trying to get an NQE scheduled to run every 5 mins. and fetch if an interface has any errors and/or if the interface utilization is high ( >90%).
With the below NQE i get an error as below - Any fields with bytes is not recognized..
ERROR: Record does not have field: "bytesOut".
interfaceUtilization(iface) = 100 * (sum(iface.bytesOut) - sum(iface.bytesIn)) / (sum(iface.bytesOut) + sum(iface.bytesIn));
where interface.adminStatus == AdminStatus.UP
utilization: interfaceUtilization(interface)
  1. Not sure why “bytes” is not recognized by the NQE
  2. How to have this scheduled to run every 5 mins ?
@venkat raj Maybe there is a misunderstanding here.  The NQE queries run against snapshot data.  Which means if you want the NQE query to be “run every 5 minutes” it means you would need to take a snapshot every 5 minutes.  You could probably achieve this with a subset of devices in a “workspace network”.  Most likely the Full network would not be able to run every 5 minutes.
What you are trying to do is more like our “Performance Data” feature.
https://docs.fwd.app/latest/application/device_performance/
That is based on SNMP collections that can be run independently of a snapshot collection.
Another comment on “bytesOut”. We don’t parse the interface stats onto the data model.  You would need to use the state file parsing to parse out that data.
  • Oct 28, 2024 3:56 PM UTC
