F5 Partition NQE not fullfil requirement
  • Oct 11, 2024 2:55 PM UTC
  • 74 views
i am using below query to get the F5 Partition details.
where device.platform.vendor == Vendor.F5
foreach c in outputs.commands
where c.commandType == CommandType.PARTITION_CONFIG
  "Partition Name": c.response
but the output is not looks good , i am also getting the Partition description in Output , i just need only Partition name only , Please help
  • Oct 11, 2024 3:22 PM UTC
@Rohit_809 Kumar I don’t have a specific example of the partition output but here is an example how you can achieve your goals.
test =
auth partition Common {
description "Default partition"
full-path /Common
inherited-devicegroup true
inherited-traffic-group true
default-route-domain 0
auth partition MyPartition {
description "Custom partition for specific applications"
full-path /MyPartition
inherited-devicegroup false
inherited-traffic-group false
default-route-domain 1
pattern =
auth partition {part_name:string}
description {desc:(string*)}
full-path {fp:string}
// foreach device in network.devices
// where device.platform.vendor == Vendor.F5
// let outputs = device.outputs
// foreach c in outputs.commands
// where c.commandType == CommandType.PARTITION_CONFIG
let config = parseConfigBlocks(OS.UNKNOWN, test)
let matches = blockMatches(config, pattern)
foreach match in matches
let data = match.data
partition: data.part_name, description: data.desc, "full-path": data.fp
See
For an example how to apply this.
