Collecting device info based on CSV of IP addresses
  • Sep 12, 2023 4:33 PM UTC
  • 266 views
I want to feed a list of ~5K IP addresses into forward and track the IP down to whatever info is available (device interface, standby address, device interface neighbor, host).
I have two functions that build the lists of records that I need to join by ip address.
FromCSV  (~5K records) and allKnownIps  (~200-300K records)
What is the most efficient / elegant way to join essentially join these tables?
I tried to build the smaller list first and then build the known IP list only if there is a match and then ran a nested loop
csvListIPs = (foreach ip in FromCSV select ip.ipAddr);// List of ~5K IPs
allknownIpList = (foreach knownIp in allKnownIps where knownIp.ipAddr in csvListIPs select ip);//Filter for only known IPs in CSVlist
foreach knownIp in allknownIpList
foreach csvIP in FromCSV
where knownIp.ipAddr == csvIP.ipaddr
select{
So I have two questions:
  1. Is there a more elegant way to do this?
  2. 5K IP's trying to match against the 250K Potential IP's (I have normalized everything so that it's ipv4 addresses in string format without a prefix) only returns about 60 matches.   Upon spot checking I am not finding any IP's that forward actually knows that is being missed here, so I suspect that the input (I don't know yet where the IP's come from) is just IPs that forward doesn't know about, but is there anything obvious I am missing here?
Best answer by jack.shen
Your first two lines
are doing the same as the next two lines
So I don’t see the benefit of having the first two lines. You can simply run a nest loop for both allnowIp and csvListIp and find IPs that exist in both list.
For your second question, it is difficult to tshoot that relies on snapshot data. Make sure allKnownIpList aggregates all the interface ip and arp entries.
I believe you could get a bit better performance by removing a foreach in this statement.
select{
known_IP: knownIp.ipAddr
The key part being
“is knownIp.ipAddr contained within the list of csvListIPs”
That they provides a “yes” or “no” answer. If Yes, finish the loop and Select this knownIp info.  If No, do not Select this address, move on to the next address in allknownIpList.
  • Sep 22, 2023 5:55 PM UTC
