WAN,INT Interfaces info through NQE query
  • June 19, 2024
  • 5 replies
  • 257 views
I want to create a custom interface description nqe query in Forward Networks.
Requirement is to getting only WAN, INT interfaces information through the query. I have used below logic through it i am not getting the results. Please help me out.
where interface.description=="WAN"
   Tags: device.tagNames,
  Vendor: platform.vendor,
  Model: platform.model,
  description: interface.description,
operStatus: interface.operStatus,
adminStatus: interface.adminStatus,
cdpNeighborsCount: length(interface.cdp.neighbors),
  lldpNeighborsCount: length(interface.lldp.neighbors)
Best answer by GaryB
@Nand
Hello great question. The evaluation you are looking for requires a “glob” match since the string “WAN” can be anywhere in the interface description.
Try using the builtin function “matches” https://docs.fwd.app/latest/application/reference/nqe/std-lib/matches/
Because interface.description maybe “null” we have to check that a description exists with the isPresent function https://docs.fwd.app/latest/application/reference/nqe/std-lib/isPresent/
where isPresent(interface.description)
where matches(interface.description, "*WAN*")
  • June 19, 2024
@Nand
  • June 19, 2024
Thank you so much
@GaryB
One last query can you please also help me for getting L2 and L3 interface column in existing query.
  • June 19, 2024
Hello @Nand , Our interface model is very extensive, Can you be more specific of the information you are looking for ?
  • June 20, 2024
@GaryB ,
want to add more in this existing query-
       1. Interface Layer (L2 or L3)
  1. double logic for description like “WAN” and “INT” or “INT’ and “int” at the same time.
  2. Port speed of Interface
  • June 20, 2024
Hello @Nand
You might consider this logic. Depending on how your descriptions are configured you might need to be more specific with your patterns.
See other ethernet details: https://fwd.app/docs/nqe/data-model/type_ethernet/​​​​​​
pattern_interfaces = ["*WAN*", "*INT*", "*otherstuff*"];
testPatterns(s, p) =
max (foreach pattern in p
select matches(toLowerCase(s), toLowerCase(pattern)));
let ethernet = interface.ethernet
where testPatterns(interface.description, pattern_interfaces)
test: testPatterns(interface.description, pattern_interfaces),
negotiatedSpeed: ethernet.negotiatedPortSpeed,
negotiatedMode: ethernet.negotiatedDuplexMode,
