Path MTU query
  • August 22, 2024
  • 217 views
what is format to pass the  the path  parameter in Path Mtu consistency check ?
is it a list of devices ?
is it a traceroute ?
or source or destination ip ?
  • August 22, 2024
Hello @rathid I believe you are looking at this query
* @intent Gets the min and max MTUs for interfaces on a path
getIface(ifaces, ifaceName) =
foreach iface in ifaces
where iface.name == ifaceName
select iface;
ifaceMtus(path) =
foreach hop in path.hops
where device.name == hop.deviceName
foreach iface in device.interfaces
foreach iface
in getIface(device.interfaces, hop.egressIfaceName) +
getIface(device.interfaces, hop.ingressIfaceName)
where isPresent(iface.mtu)
select iface.mtu;
@query
getPathMtuInfo(path: Path) =
foreach mtus in [ifaceMtus(path)]
let minMtu = min(mtus)
let maxMtu = max(mtus)
select { "Min MTU": minMtu, "Max MTU": maxMtu, violation: minMtu != maxMtu };
This query is designed to be used as a Path Decorator you can learn more about Decorators here https://fwd.app/docs/enterprise/applications/nqe/nqe_decorators/
When enabled, you will see the decorator below the path indicating the Min, Max and Violation for a path. So to answer your question, In this query you don’t pass anything into that function, it happens automatically in-platform.
  • August 22, 2024
@rathid The decorators are meant to ingest a bunch of information from a path trace.  Putting that information into the query manually is not very practical.
A path trace starts with a source and destination ip address, but then once the path is calculated there is a lot of data that is returned about each hop.
The decorator queries are not good for an automated workflow, they are good at showing extra data about a path in the UI.  There is just a lot of data that would have to be passed in if you tried to do it manually.
The decorator format is really good for the decorator feature.  For doing your own MTU check, it is better to use a non-decorator query.
-Tyson
