match two lines with different amounts of output
  • March 25, 2024
  • 338 views
I have a problem where the two lines of this module output are not the same.  How can I put in essentially null place holders so that they resultant patterns are the "same"?
example output
Notice that module 2 does not have Fw or Sw.
Mod MAC addresses                    Hw  Fw           Sw               Status
1 a03d.6f81.0740 to a03d.6f81.074f 1.1 15.0(1r)SG12 03.07.03.E Ok
2 b0aa.777d.d010 to b0aa.777d.d017 1.0 Ok
I was trying to use these two patterns and tried to put in placeholds of Fw and Sw at the end of "pattern03".  But the NQE does not like this.
pattern02 =
Mod MAC addresses
{modNum:number} {string} to {string} {hwVer:string} {fwVer:string} {swVer:string} {modStatus:string}
pattern03 =
Mod MAC addresses
{modNum:number} {string} to {string} {hwVer:string} {modStatus:string} {fwVer: null:string} {swVer: null:string}
getMacAddrList(parsedOutput) =
foreach pattern in [pattern02, pattern03]
foreach match in blockMatches(parsedOutput, pattern)
select match;
  • March 25, 2024
It appears that the output you are trying to parse is a fixed format.  I do realize that tabs and other non-printing characters might be lurking in the output but perhaps you can assume the row is “oneBigString” and use Sting functions to grab just certain data chunks.  Say anything from position X in the oneBigString for Y characters is a particular dataValue.
  • March 27, 2024
I chose to use two different user functions.  One had a pattern to match all columns.  The other to match output with two missing columns.  If there is ever a third, then I will be out of luck.
But then in the second user function.  In the Select statement.  I could add “columnX: null:String” and “columnY: null:String”.  Now all of the columns are accounted for and I can now add those two lists together.
  • May 20, 2024
If the hw and fw levels are not important. Then you could use a single pattern.
sometext = """
{n:number} {a:macAddress} to {b:macAddress}
let blocks = parseConfigBlocks(OS.UNKNOWN, sometext)
foreach match in blockMatches(blocks, pattern)
select
a: match.data.a,
b: match.data.b
The indent on the numbers may be something of interest though if we have 2 digits modules.
  • May 20, 2024
These can be tricky, You could leverage Approach 3 in my series on patternMatching Three techniques for pattern matching text with patternMatch, patternMatches and blockMatches
text = """
findTokenCount(s) = length(patternMatch(s, `{string*}`));
pattern02 =
`{modNum:number} {string} to {string} {hwVer:string} {fwVer:string} {swVer:string} {modStatus:string}`;
pattern03 =
`{modNum:number} {string} to {string} {hwVer:string} {modStatus:string}`;
normalizeBlocks(blocks) =
foreach line in blocks
foreach child in line.children
let var_count = findTokenCount(child.text)
select if var_count == 8
then patternMatch(child.text, pattern02)
else if var_count == 6
then patternMatch(child.text, pattern03)
else null : {modNum: Number, hwVer: String, modStatus: String};
let blocks = parseConfigBlocks(OS.UNKNOWN, text)
foreach block in normalizeBlocks(blocks)
block
