How to isolate a single commandType output for parsing?
  • October 31, 2024
  • 99 views
I am trying to get the output from commandType NHRP_STATE so I can then pull out the tunnel peer IPs with a patternmatch.
When the NHRP table was a custom command the command.commandText was able to get this information, now how to do so that NHRP is part of the data model?
Best answer by AricaFN
where command.commandType == CommandType.NHRP_STATE
let response = parseConfigBlocks(device.platform.os, command.response)
foreach match in patternMatches(response, pattern)
This will allow you to define your pattern and match it against the command output.
AricaFN
  • October 31, 2024
  • October 31, 2024
Thanks - I had gotten misled by the lowercase commandType vs the uppercase C CommandType to call it in the data model.
  • October 31, 2024
The case is trying to be a difference between the lowercase position on the model tree and the upper case data type.  Unfortunately it is confusing.  If you hover over the commandType in “command.commandType” you will see a popup showing a yellow “CommandType” which indicates the data type.  The data type is what you use on the right hand side of the ==.
