How to Integrate ServiceNow (SNOW) with Forward Enterprise
  • Apr 2, 2025 3:53 PM UTC
  • 555 views
Forward Enterprise can integrate with ServiceNow in the following ways:
Incident Management - Opening or updating a ServiceNow ticket based on an intent verification failure or change:
Forward Docs - Create ServiceNow Incidents
CMDB Integration - Pushing updates to the CMBD database with data from Forward Enterprise:
Forward Docs - CMDB Integration
As a Data Connector with NQE - Extracting data from ServiceNow using an NQE query for use in the NQE Library, Inventory+, or a Decorator by configuring ServiceNow as a Data Connector:
Forward Docs - Data Connectors
From ServiceNow - By using Flow Designer or Business Rules to access the Forward API. Consult ServiceNow documentation and access one of Forward Enterprise’s API endpoints listed here:
Forward Docs - API
The first two integration types above are enabled under Settings > Integrations:
The following article shows how to use the Forward API to automate workspace network creation, collection, and diff comparison for Change Control validation. This could be orchestrated using ServiceNow.
  • Apr 3, 2025 3:48 PM UTC
Hey,
Im attempting to integrate with ServiceNow but unable to access documentation. Presents login.
  • Apr 3, 2025 4:12 PM UTC
​@leafsmell
If your Forward Enterprise deployment is SaaS (fwd.app), you will need to log in with your Forward Credentials (or SSO, depending on how your org configured login).
If your Forward Enterprise deployment is on-premises, then replace the “fwd.app” portion of the link with the domain of your Forward Enterprise URL and log in.
  • Apr 4, 2025 8:04 AM UTC
Hey,
Thanks for replying..im an integrating partner and so i dont have access to the customers enterprise platform and given the nature of the business/industry im not likely to either. Is there any other way I can access the documentation?
This is for ServiceNow integration to pull data in.
