Forward Network application (system) monitoring
  • Dec 17, 2024 8:06 PM UTC
  • 394 views
can Forward Network application (itself) integrate with Grafana, or Sysdig for monitoring the system health (i.e. cpu, memory, logfile, processes, filesystem) attributes. would like to send to dashboard tier team monitoring
Best answer by joe
Hi ​@hdrew - for an on-prem deployment, check out the info below. It’s also available in the docs at https://docs.fwd.app/latest/on-prem/administration/monitoring/
To monitor the health of the cluster and its instances, Forward provides a configurable Dashboard based on Grafana available at https://<PRIMARY_NODE_IP>/monitoring.
Credentials
Viewing the default dashboard is open to anonymous users. Admin users can add more dashboards. The default credentials for the admin password are:
  • user: admin
  • password: admin
You will be prompted to change the admin password the first time you log in.
joe
  • Dec 17, 2024 8:54 PM UTC
Credentials
  • user: admin
  • password: admin
  • Dec 20, 2024 4:14 PM UTC
​@joe thank you for responding to my posting. I am going to do some research on the provided fwd.app doc.  I am curious if you could comment if Forward also can possibly connect to Sysdig as well.
  • Dec 20, 2024 8:53 PM UTC
Hi ​@hdrew ,
There may be something we can do to connect Forward deployment to Sysdig. Lets discuss offline so we can look into your specific deployment.
Regards,
Jack
