What the Air Force Taught Me About Seeing Networks Clearly
  • Nov 25, 2025 8:54 PM UTC
  • Feb 27, 2026 12:16 AM UTC
  • 159 views
devecis
Where My Network Survey Lessons Really Began: High-Security Environments
I’ve spent years surveying some of the most complex, layered, and mission-critical networks in high-security environments. One of the most impactful experiences came from supporting the Air Force’s Base Infrastructure Management (BIM) initiative—a massive effort to modernize, standardize, and truly understand the state of base-area network (BAN).
These networks weren’t designed once; they were designed over time—by different teams, different contractors, and different mission owners. Every environment had its own personality, its own quirks, and its own technical ghosts. And when BIM kicked off, it quickly became clear that the Air Force needed a repeatable way to actually see what they had before they could improve it.
Traditional approaches—flying in engineers to open comms closets and manually log into devices—took weeks and still left blind spots. We needed a better, faster, more reliable way to uncover the truth.
That’s where modern network surveys come in.
Understanding the Network Beneath the Diagrams
A network survey is the moment when assumptions collide with reality.
It’s not just collecting serial numbers or capturing a few configs. It’s a structured process to answer big, often uncomfortable questions:
  • What devices really exist on this network?
  • How are they configured right now—not last year?
  • What roles do they play, and what traffic actually depends on them?
  • Are they still supported by vendors, or far past end-of-life?
  • Does the behavior of the network match the mission it’s supposed to support?
For programs like BIM, which depend on accurate baselines before modernizing anything, surveys are foundational. You can’t redesign, secure, or optimize a network you don’t truly understand.
A good survey exposes the gap between the intended design and the lived-in reality of an enterprise network. It replaces folklore with facts.
Collecting Network Truth When You Can’t Install Anything
Highly regulated and high-security networks operate under constraints most commercial environments never face. You can’t install just anything. You need approvals. You may be working in air-gapped or classified environments where even moving data between enclaves requires one-way guards and information assurance (IA) reviews.
Instead of fighting those constraints, we built our survey approach specifically to work within them.
The Headless Collector
Most Forward Enterprise deployments use a standard SaaS or on-prem collector appliance. But in regulated networks, installing software often triggers months of ATO paperwork.
The headless collector provides a stop gap while ATO is in progress. It’s a single binary you can run from:
  • A laptop
  • A temporary VM
  • A small, approved node inside the network
It logs into devices, discovers the environment, and gathers all the data needed for a full network model—but it doesn’t have to be installed in the traditional sense.
Because it isn’t persistent, it only needs an IA review, virus scanning, and documentation—not a full Authority to Operate (ATO). That one difference means teams—including BIM rollout teams—can start collecting real data on day one.
Why the Headless Collector Is Essential in Regulated Environments
Speed and transparency matter. With the headless collector:
  • You can start gathering data immediately—even before approvals for persistent software are complete.
  • The output is plain text—inspectable and auditable by any security team.
  • It fits neatly into approved file-transfer processes (secure portals, one-way guards, internal enclaves).
This capability became a force multiplier during BIM surveys and similar federal modernization efforts. It’s the fastest way to build situational awareness in environments where agility is traditionally impossible.
From Raw Data to Real Understanding
When the collector finishes, it generates a snapshot zip file containing device inventory, configurations, topology, compliance details, and lifecycle data. You move that file through approved channels back to your primary Forward Enterprise environment.
Upload it, and within minutes you have a complete, navigable digital twin of that network—no persistent deployment required. It’s fast, clean, and scalable across regions or entire organizations.
The Results of an Effective Network Survey
The first thing you see after ingesting a snapshot is the truth—sometimes reassuring, but more often eye-opening.
A real survey doesn’t just tell you what devices exist; it reveals how the network behaves and where risk actually lives. Once the data loads into Forward Enterprise, you gain clarity across several essential dimensions:
Inventory — All discovered devices, where they sit, and the roles they play
Configurations — The actual configs running in production, not the “intended” versions saved in a repo years ago
Compliance Posture — STIG checks, audit artifacts, and other policy validations that show whether the network meets required standards
Lifecycle Risk — Identification of end-of-life or end-of-service hardware and software, along with devices that may still function but rely on OS versions that fell out of support long ago
Behavioral Context — What the network is actually doing (not what diagrams assume), including which ACLs and route maps enforce security and routing behavior
These insights were especially important during BIM assessments. They exposed forgotten firewalls, shadow devices, outdated gear tucked in unexpected places, and routing logic that no longer aligned with mission needs.
More importantly, a survey shows whether the network still aligns with the mission. BIM’s core mandate—modernize and secure base infrastructure—depends on that clarity.
With vulnerability cycles shrinking, having an accurate, current survey isn’t optional—it’s operational survival.
How You Can Start Your Network Survey Today
You don’t need a massive modernization project like BIM to get started.
Begin by understanding your baseline: how many devices, which sites matter most, and what the network is supposed to achieve. Talk to the people who depend on it—operations leads, security teams, and mission owners—to understand what “success” means from their perspective.
From there:
  • If you can’t, run Forward’s headless collector to gather your first real snapshot.
  • Ingest the snapshot into your Forward platform.
Once you have that foundation, begin evaluating what’s outdated, misconfigured, risky, or simply out of alignment with your network’s purpose. And most importantly, make surveys a routine operational discipline rather than a one-off event.
The more current your understanding of the network, the easier it becomes to modernize, secure, and defend it.
