What's New: Smarter, More Secure On-Premises Appliance Administration in versions 16.5 and 17
  • May 14, 2026 11:48 PM UTC
  • 84 views
Managing an on-premises network intelligence platform should be straightforward — and with Forward Enterprise Appliance 16.5 and the upcoming version 17, we're making it significantly easier and more secure.
Here's what's changing and why it matters.
A New Way to Administer Your Appliance
Starting with version 16.4, we introduced a Text User Interface (TUI) — a guided, menu-driven environment accessible via SSH or the console. Rather than navigating the underlying Linux OS directly, administrators now have a single, purpose-built interface for every common task.
The TUI covers everything from initial node configuration and cluster deployment to Forward Enterprise upgrades, security settings, and built-in diagnostics — all in one place.
Version 16.5: Refinements Based on Your Feedback
Forward Enterprise Appliance 16.5 (available May 2026) is the last release in the 16.x line to include open shell access. It brings vulnerability fixes and TUI improvements based on early adopter feedback. If you're currently on 16.4, now is a great time to upgrade and get comfortable with the TUI before the transition to version 17.
Version 17: The Closed Appliance Model
With version 17, arriving July 2026, the appliance moves to a fully closed model. Direct shell access will no longer be available by default. In the rare cases where OS-level access is genuinely needed — for advanced troubleshooting, for example — administrators can request a time-limited, one-time authorization password from Forward Networks.
This approach ensures system access remains controlled and auditable while still supporting legitimate operational needs.
Why This Is Good for Your Operations
The benefits extend well beyond security. Teams no longer need deep Linux expertise to handle routine appliance management. Configuration drift between cluster nodes becomes a thing of the past. Deployment workflows are standardized and repeatable. And when something does go wrong, our support teams can diagnose issues faster because system state is predictable and consistent.
Timeline at a Glance
Milestone
Date
16.4 — TUI introduced
March 2026
16.5 — Last release with shell access
May 2026
Version 17 — Closed appliance model
July 2026
End of support for 16.x
August 2027
What You Should Do Now
If you're running 16.x, begin familiarizing your team with the TUI today. Plan your upgrade path to version 17 ahead of the July release. And if you have questions or feedback on the TUI experience, we want to hear it.
Full documentation and upgrade guidance are available in the Forward Networks support portal.
