What outside access does Forward need?
  • Sep 12, 2023 1:45 AM UTC
  • 160 views
area_man
Can you confirm where Forward would need access to upgrades so we can add those policies to our Firewall? (Ex AWS, S3, Gitlab etc). Also, if there’s any other reason Forward Networks would need to reach externally.
Thanks
Best answer by joe
Hello!
On-prem instances of the Forward Platform do not require internet access. If you have air-gapped your platform, app upgrades can be performed manually by downloading the upgrade from another internet-connected system and applying the upgrade manually.
I hope this helps!
-Joe
joe
  • Sep 12, 2023 5:08 PM UTC
Hello!
I hope this helps!
-Joe
