How can i remove some static values for output.
  • Apr 2, 2025 9:37 AM UTC
  • 100 views
we are using below NQE Query to get the NTP Server details , i need to remove some static value in  server coloum,
ciscontppattern=
ntp server {server:string}
getServers(device) =
  foreach match in blockMatches(device.files.config, ciscontppattern)
  select { serverIP: match.data.server};
   vendor: device.platform.vendor,
    tags: device.tagNames,
    os: device.platform.os,
    OSVersion :platform.osVersion,
  servers: (foreach server in getServers(device)
            select server.serverIP)
Example : i dont want to show entry those have server value - “Inte”
  • Apr 2, 2025 12:39 PM UTC
​@Rohit_809 Kumar Have you tried matches
vals = ["preSomeName", "SomeNamepost", "other"];
matchTest = ["pre*", "*post"];
foreach v in vals
foreach m in matchTest
select { v: v, m: m, r: matches(v, m) }
​@Rohit_809 Kumar There will be a few ways to handle this.  Gary mentioned on.  I’ll try to show another
You could use an “if” statement to make adjustments to the server names.
let serverName = if matches(match.data.server, “Inte*”)
                                   then suffix(match.data.server, length(match.data.serve) - 4)
                                  else match.data.server
This way only if the server name starts with “Inte” then you will use the “suffix” function to but of the “Inte” letters.  If it does not start with “Inte” then you don’t need to do anything.
This function suffix(match.data.server, length(match.data.serve) - 4).  The thing here is that I don’t know how long the full server name is.  So I use “length(match.data.serve) - 4” to say that starting from the back end of the server name, show me all but the first 4 characters.
