Don’t Marry the Model: Designing Flexible AI Workflows
  • Mar 11, 2026 12:15 PM UTC
  • 70 views
devecis
The Bottom Line Up Front (BLUF)
In networking, we’ve spent decades eliminating single points of failure — redundant power, redundant links, redundant clusters.
Recent policy shifts affecting AI providers are a reminder that AI models themselves can become a new kind of single point of failure.
When organizations suddenly need to stop using a specific model due to policy, regulatory, or geopolitical reasons, entire workflows can break overnight.
That’s why model-agnostic architectures are quickly becoming a requirement, not a luxury.
A New Kind of Risk
Engineers usually think about failure in technical terms:
  • hardware failure
  • network outages
  • power loss
AI introduces a different category of risk.
If your product, automation pipeline, or internal workflow relies entirely on one AI provider, your roadmap becomes tied to that provider’s regulatory and business environment.
That dependency may work fine today — until it doesn’t.
The lesson here isn’t about which model is best. It’s about architectural resilience.
Don’t Marry the Model. Marry the Workflow.
One of the most common mistakes in AI architecture is designing systems around a specific model.
But the “best” model changes constantly.
A single announcement, release, or policy shift can reshape the landscape overnight.
The safer strategy is simple:
Build workflows that can survive losing any individual model.
Your AI stack should treat models like interchangeable components — not permanent dependencies.
What a Resilient AI Workflow Looks Like
To see the difference, let’s compare two approaches:
The Locked-In Workflow
Your application:
  • calls a specific model API
  • uses provider-specific prompt formatting
  • depends on model-specific features
If that model becomes unavailable, the entire system breaks.
Now you’re rewriting code, prompts, and integrations just to restore functionality.
What’s the second approach?
The Model-Agnostic Workflow
Instead of wiring your application directly to a model, introduce an abstraction layer using something like the Model Context Protocol (MCP).
Your application talks to a standard interface, not the model itself.
If Provider A becomes unavailable, you don’t rewrite the workflow. You simply route it to Provider B.
Your tools and data connectors remain unchanged because they connect through standardized interfaces.
Think of it as a universal socket for AI models.
Three Practical Steps to De-Risk Your AI Strategy
1. Inventory Your Prompt Dependencies
Lock-in doesn’t only happen at the API layer.
It can happen in prompt design as well.
If your prompts rely on a specific model’s quirks or formatting, switching providers becomes harder.
Maintain prompt variants for multiple model families and version them like code.
2. Standardize Data Access with MCP
Expose your systems through Model Context Protocol (MCP) servers rather than building custom integrations for every tool.
This separates:
  • the AI model (“the brain”)
  • from the tools and data it interacts with (“the hands”)
Swap the brain and the hands keep working.
3. Keep CLI Tools as a Universal Backup
Another resilience strategy is enabling AI agents to use standard command-line tools.
Models trained on code already understand tools like:
  • git
  • curl
  • sql-cli
CLIs are essentially a universal language for automation, making them a reliable fallback when specialized APIs change.
Technical Sidebar: Why MCP Matters
Think of MCP like USB-C for AI systems.
In the past, every device required its own charger. Switch devices, and suddenly your cables were useless.
MCP standardizes that connection.
You define your data interfaces once through an MCP server running on your infrastructure. Any compatible model can connect to it.
It’s the difference between building on a stable foundation and building on a rented boat tied to a single vendor.
A Familiar Pattern for Network Engineers
If you’ve spent time in network architecture, this pattern should feel familiar.
Networks rarely depend on one vendor or implementation. Instead, they rely on abstraction layers and standardized protocols so the underlying components can change without breaking the system.
Protocols like BGP, TCP/IP, and DNS exist to decouple systems from the hardware underneath them.
AI architectures are beginning to follow the same pattern.
When workflows, data access, and model selection are separated, systems gain the flexibility to adapt as the ecosystem evolves.
Resilience doesn’t come from picking the “right” model.
It comes from designing systems where no single component is irreplaceable.
The Bottom Line
The organizations that succeed with AI won’t necessarily be the ones that pick the “best” model today.
They’ll be the ones that build flexible environments where any model can operate.
Network engineers solved this problem decades ago by designing systems around visibility, abstraction, and interchangeable components.
AI architectures are simply catching up to the same lesson.
The real competitive advantage isn’t the model.
It’s the architecture around it.
I’m curious how others are approaching this
Are you experimenting with multi-model architectures yet, or standardizing on a primary provider? Let me know below.
