DeviceCollectionError Descrptions and sequence of PHASEs?
  • Jan 8, 2024 7:33 PM UTC
  • 208 views
I am working on automated resolution of failed connections.   Two questions: (1) On this page in the documentation: /docs/nqe/data-model/type_devicecollectionerror/  there is a list of errors but no descriptions.  Can someone provide? (2) I am studying a failure report and the Connect Test Status notes each of these in PHASEs which seems to imply that each is determined in a sequence.  Is there a list of PHASE order for these?
AUTHENTICATION_FAILED-AUTHENTICATION PHASE
AUTHORIZATION_FAILED-AUTHORIZATION PHASE
CONNECTION_FAILED-CONNECTION PHASE
DEVICE_IS_CHILD_CONTEXT-SETUP PHASE
DEVICE_TYPE_MISMATCH-TYPE_DISCOVERY PHASE
DEVICE_TYPE_UNDETECTED-TYPE_DISCOVERY PHASE
GUEST_MISSING_HOST_RESULTS-SETUP PHASE
JUMP_SERVER_AUTHENTICATION_FAILED-CONNECTION PHASE
JUMP_SERVER_CONNECTION_FAILED-CONNECTION PHASE
OTHER-AUTHORIZATION PHASE
PING_FAILED-CONNECTION PHASE
PORT_REACHABILITY_FAILED-CONNECTION PHASE
PRIV_PASSWORD_ERROR-SETUP PHASE
PROMPT_DISCOVERY_FAILED-SETUP PHASE
SESSION_CLOSED-TYPE_DISCOVERY PHASE
TIMED_OUT-AUTHENTICATION PHASE
TIMED_OUT-AUTHORIZATION PHASE
TIMED_OUT-SETUP PHASE
TIMED_OUT-TYPE_DISCOVERY PHASE
Unfortunately it does not come up in the search.  It is under
https://docs.fwd.app/latest/application/getting_started/configure_collection/troubleshooting/
Collection troubleshooting.  That has the errors plus a short description.
  • Jan 8, 2024 10:44 PM UTC
  • Jan 9, 2024 4:51 PM UTC
Tyson, Thanks as always for the prompt response.  This helped.  Moving forward it would be handy to link the labels/values on the link you provided to the labels/values, and to include descriptions of those on the page instead of just ‘...’  in my original post.
I am also still looking to see if each of the PHASEs listed is followed in a particular order.
