Collecting custom command "show configuratation" within a a Cisco FPR running on FXOS
  • Oct 21, 2024 11:07 AM UTC
  • 232 views
For reference - we recently were able to get Cisco Firepower ASA operating as FTD and FPRs on IOS FXOS, for the first time.  With that….
Since none of the default commands produce any data in the state files, we are trying to use custom commands.  Right now, when performing a show run, it comes back with 25 lines of configs, but then stops at --More--, which is when a user via cli would would push a button.  We have lots of other devices running custom commands that do not do this, so why is it happening with FXOS and how can we work around it?
Also, the FTD devices reporting all state files properly, its just the FPRs that are having issues.
  • Oct 21, 2024 6:29 PM UTC
Hi @gbaron I investigated your question with engineering.
We agreed that you should open a support case on this.
