A Guide to S3 Pre-Signed URLs: What They Are and How They Work
  • Feb 25, 2025 9:20 PM UTC
  • Apr 7, 2025 11:44 PM UTC
  • 1899 views
chrisnaish
This video explores S3 pre-signed URLs, explaining their purpose, benefits, and how they function. It also includes a demonstration of creating and using pre-signed URLs in the AWS Management Console and highlights their integration within the Forward Networks platform for secure and efficient workflows.
Summary: Pre-Signed URLs in Forward Networks
Pre-signed URLs enable secure, temporary access to private S3 bucket objects without exposing credentials. In Forward Networks, they are used for non-SaaS VM installations and upgrades, allowing users to download overlays and package upgrade files from Software Central.
Why They Matter:
  • Secure Access: Prevents unauthorized access while allowing necessary downloads.
  • Time-Limited Links: URLs expire (e.g., 30 minutes), reducing security risks.
  • Automation & Ease of Use: Clicking "Copy Command" generates a pre-signed URL for quick access via command-line tools like curl.
This ensures that VM deployments and upgrades remain efficient, automated, and secure without making S3 buckets public.
What Is an S3 Pre-Signed URL?
An S3 pre-signed URL is a secure, time-bound link that allows temporary access to specific objects stored in a private S3 bucket. Unlike traditional access methods that rely on long-term credentials or bucket-wide permissions, a pre-signed URL leverages existing authentication credentials to create a URL that grants limited access to a single object for a specified duration. This approach enables secure sharing without exposing sensitive credentials or making the bucket public.
Why Are Pre-Signed URLs Important?
Private S3 buckets are the default setting in AWS, ensuring that stored objects are inaccessible to the public. While this is excellent for security, scenarios often arise where temporary access to a specific file is necessary. Conventional options for granting access include:
  1. Sharing AWS credentials.
  2. Creating temporary accounts for external users.
  3. Making the S3 bucket publicly accessible.
These methods are either insecure or impractical, especially for short-term access. Pre-signed URLs resolve these issues by:
  • Allowing users to securely share objects without exposing credentials.
  • Maintaining the private nature of the bucket while granting temporary access.
  • Simplifying access management through automated expiration.
How Do Pre-Signed URLs Work?
1. Generating a Pre-Signed URL
The process of creating a pre-signed URL in the AWS Management Console is straightforward:
  • Navigate to the private S3 bucket and select the desired object.
  • Choose "Share with pre-signed URL" under the object’s Actions menu.
  • Specify an expiration time (e.g., 1 minute, 30 minutes, or a custom duration).
  • Generate the URL, which is immediately copied to the clipboard for sharing.
2. Using the URL
When accessed within the specified timeframe, the URL provides direct access to the object, bypassing the need for authentication credentials. Once the expiration time elapses, the URL becomes invalid, ensuring secure and time-limited access.
3. Key Components of the URL
Each pre-signed URL contains essential elements that enable secure and temporary access:
  • Object Location: The specific path to the file in the S3 bucket.
  • Security Token: A temporary token that validates the request.
  • Expiration Timestamp: The exact time at which the URL will expire.
  • Authentication Signature: A cryptographic signature that ensures the URL can only be used as intended.
4. Demonstrating Expiration
Testing a pre-signed URL involves attempting to access it after its expiration time. For example:
  • Accessing the URL immediately shows the object.
  • Refreshing the URL after the timer expires results in an "Access Denied" error, confirming the security mechanism.
Practical Application in Forward Networks
Pre-signed URLs are seamlessly integrated into Forward Networks' platform, providing critical functionality for tasks like Forward VM installations and upgrades.
Use Case in Software Central Portal
In Forward Networks’ Software Central Portal, users have the option to download VM images and upgrade packages using pre-signed URLs generated through "Copy Download Command" buttons:
  • Step 1: Clicking the button generates a unique pre-signed URL for the requested file.
  • Step 2: The URL is valid for 30 minutes, giving users ample time to complete the download.
  • Step 3: If the URL expires, users can simply click the button again to generate a new one.
Behind-the-Scenes Functionality
The URLs generated in Software Central use the same principles demonstrated in AWS:
  • They are tied to specific S3 buckets managed by Forward Networks.
  • Security tokens, authentication signatures, and expiration timestamps ensure secure, controlled access to files.
This implementation streamlines VM deployments and upgrades, providing a user-friendly and secure way to manage critical files.
Advantages of S3 Pre-Signed URLs
Enhanced Security:
  • Keeps private buckets secure by avoiding public access or credential sharing.
  • Includes built-in expiration to limit the duration of access.
Ease of Use:
  • Quick to generate and share, requiring minimal configuration.
  • Accessible through common interfaces like the AWS Console or platform-specific integrations.
Flexibility:
  • Supports both GET (download) and PUT (upload) operations.
  • Customizable expiration times cater to varying access needs.
Practical Integration:
  • Ideal for platforms like Forward Networks, where secure, temporary access is essential for tasks like software updates.
Conclusion
S3 pre-signed URLs are a robust, flexible, and secure solution for granting temporary access to private S3 objects. They address common challenges associated with sharing files securely, making them an indispensable tool in workflows that demand simplicity and security. Their integration into the Forward Networks platform exemplifies how this feature can be used to streamline operations like VM installations and upgrades while maintaining rigorous security standards. Whether for personal use or enterprise-scale applications, pre-signed URLs are a vital feature for modern cloud operations.
