Forward Enterprise as BGP Receiver
  • Jan 4, 2024 6:15 PM UTC
  • 242 views
deronjohnson
Collecting BGP RIB from all devices is tedious to collect the data and process it. Industry standard solution to this problem is BMP (BGP Monitoring Protocol) which Cisco, Juniper and other vendors have implemented.
BMP should expose/advertise the routes from all address families configured. Cisco has implemented only “ipv4 unicast” address family exposure, that limits the usefulness of BMP in Cisco based devices.
Forward Networks has come up with a solution to the problem where Forward Collector, or the VM, will act as a BGP receiver and collect data from all available address families.  As a BGP receive the Forward Collector works as a BGP route-reflector client, so this peering is specifically with the BGP route-reflector in the network.
Note this feature is exclusive to Cisco IOS XR devices
How it works:
  • Instead of collecting BGP RIB from all devices, Forward Enterprise will peer to a single IOS XR, that is acting as a route-reflector, and will reflect routes to Forward Enterprise.
  • Forward Enterprise will bring up a BGP receiver process only during the snapshot collection process. Which means this peer will show in the “active” state from the Route-reflector’s point of view, when collection is not in process.
  • There are no BGP configurations required on the Forward Platform.  It is just a checkbox, under the route-reflector, in the device list.
  • For the device where the checkbox is enabled, the Forward Platform will first collect the running configuration of the device.  Then, the Forward Platform will inspect the BGP configuration to find if there is a route-reflector client configured for the Forward Platform’s ip address.  Following this inspection the Forward Platform will then find the appropriate BGP AS from the command “Remote-as” in the peering statement, to use during the peering.
  • The BGP session will be established only during the snapshot collection. At all other times the neighbor state on the BGP route-reflector will be either Active or Idle. This is an expected behavior.
Steps to enable:
  • Navigate to Connection => Collector => Advanced network collection settings and enable all settings under “BGP advertisements” section. This is a global option allowing the platform to collect. This will not automatically collect BGP RIB from all devices but is required
  • Navigate to Collection => Collector => Devices and select the device that acts as Route Reflector, click on “Edit”, navigate to “Advanced Settings” and enable/check “Enable collection of BGP advertisements”
Note: this is a per-device setting and Forward Enterprise will collect only from the devices that have this setting enabled
Sample Topology:
DEVICE
DEVICE NAME
IP ADDRESS
Forward Collector
fncollect01
7.64.101.10
Route Reflector
XR-RR1
11.255.6.100
The topology below is a simple service provider network with (3) P devices, (4) PE devices and (3) customers under VRF RED, BLUE and GREEN.
DEVICES
VRF
CUSTOMER
CE11, CE12
RED
Customer 1
CE21, CE22
BLUE
Customer 2
CE31, CE32
GREEN
Shared VRF for common services. Customer 1 and 2 can access CE31 and CE32 and vice versa
BGP AS details:
DEVICE
BGP AS NUMBER
IP ADDRESS
Forward Collector
600
7.64.101.10
XR-RR1
600
11.255.6.100
P1
600
11.255.6.1
P2
600
11.255.6.2
PE1
600
11.255.6.11
PE2
600
11.255.6.12
PE3
600
11.255.6.13
PE4
600
11.255.6.14
CE11
100
192.168.11.100
CE12
100
192.168.12.100
CE21
200
192.168.21.100
CE22
200
192.168.22.100
CE31
300
192.168.31.100
CE32
300
192.168.32.100
Topology:
XR-RR1 BGP Configuration
route-policy RPL_DENY_IN
  drop
end-policy
route-policy RPL_PERMIT_OUT
  pass
end-policy
route-policy RPL_PASS_ALL
  pass
end-policy
router bgp 600
 address-family ipv4 unicast
  network 11.11.6.0/24
  network 11.255.6.100/32
  network 11.255.66.100/32
 address-family vpnv4 unicast
 neighbor-group AS600-RR
  remote-as 600
  update-source Loopback0
   route-policy RPL_PASS_ALL in
   route-reflector-client
   route-policy RPL_PASS_ALL out
   advertise vpnv4 unicast
 neighbor 11.255.6.1
  use neighbor-group AS600-RR
 neighbor 11.255.6.2
 neighbor 11.255.6.3
 neighbor 11.255.6.4
 neighbor 11.11.6.250
  remote-as 666
 neighbor 11.255.6.11
  remote-as 600
 neighbor 11.255.6.12
  remote-as 600
 neighbor 7.64.101.10
  remote-as 600
   route-policy RPL_DENY_IN in
   route-policy RPL_PERMIT_OUT out
BGP state on XR-RR1 during snapshot collection:
Note that we have only “IPV4 Unicast” and “VPNV4 Unicast” address families enabled but will work with all other Address families as well
RP/0/0/CPU0:XR-RR1#sh bgp all all summary
Wed Mar 25 15:11:11.674 UTC
Address Family: VPNv4 Unicast
BGP router identifier 11.255.6.100, local AS number 600
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0x0   RD version: 0
BGP main routing table version 37
BGP NSR Initial initsync version 1 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
BGP is operating in STANDALONE mode.
Process   RcvTblVer   bRIB/RIB   LabelVer  ImportVer  SendTblVer  StandbyVer
Speaker          37     37     37     37      37       0
Neighbor    Spk AS MsgRcvd MsgSent   TblVer  InQ OutQ  Up/Down  St/PfxRcd
7.64.101.10   0   600  31  86    0 0 0 00:00:00      0
11.255.6.1    0   600 2731 2475   37 0 0 1d16h      2
11.255.6.2    0   600 2731 2475   37 0 0 1d16h      4
11.255.6.3    0   600 2728 2474   37 0 0 1d16h      4
11.255.6.4    0   600 2724 2472   37 0 0 1d16h      2
Address Family: IPv4 Unicast
Table ID: 0xe0000000   RD version: 77
BGP main routing table version 77
BGP NSR Initial initsync version 2 (Reached)
Speaker          77     77     77     77      77       0
11.11.6.250   0   666 2628 2532   77 0 0 1d16h      4
11.255.6.11   0   600 2816 2518   77 0 0 1d16h     21
11.255.6.12   0   600 2819 2519   77 0 0 1d16h     21
BGP state on XR-RR1 during idle time:
Wed Mar 25 15:10:45.526 UTC
7.64.101.10   0   600  29  84    0 0 0 00:02:35 Active
11.255.6.1    0   600 2730 2475   37 0 0 1d16h      2
11.255.6.4    0   600 2723 2472   37 0 0 1d16h      2
7.64.101.10   0   600  29  84    0 0 0 00:02:36 Active
11.255.6.12   0   600 2818 2519   77 0 0 1d16h     21
