How can i add Custom command for fortinet.
command that i am looking.
- show system dns.
- show system ntp.
- show system central-management config system central-management.
Check out the Docs in the following link. One needs to be logged into the FN Platform to see the Docs.
https://fwd.app/docs/enterprise/getting_started/configure_collection/devices/custom_commands/
There is a Fortinet example here:
That should get you started. There are quite a few examples of parsing Custom Commands in the Community. Let us know if you get stuck or have additional questions. Note that one needs to run a Snapshot to execute the Custom Commands.
Thanks
Already have an account? Login
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
