Using NQE to validate uplink on ACI Fabrics
  • May 17, 2024
  • 217 views
Problem Statement
Our company had issues where some network leafs were not connected to all our spines within an ACI fabric.Traditional methods to validate this were time consuming so we developed a basic NQE query to assist.
How it works
we leverage the LLDP information for the network leaves and match this to our spines. In our case, we rely on the device naming convention to match LLDP entries to spines. Our spines have SP within the name.
NQE Script
Function to gather the links to spines for a given device
* function: countSpineNeighbours
* parameters: device: Device
* purpose
* count the number of links that are between the spines and the leafs
* spines are matched based on the SP in the device name, at position 8
* returns: dict
* deviceName: string
* interfaceName: string
countSpineNeighbours(device) =
where interface.interfaceType == IfaceType.IF_ETHERNET
foreach n in interface.lldp.neighbors
where length(n.deviceName) >= 10 && substring(n.deviceName, 8, 10) == "SP"
deviceName: n.deviceName,
intefaceName: interface.name
Main script iterates over all devices, picking out any leaf nodes based on a tags, device type and naming convention. These are then processed using the function countSpineNeighbours to see if there are 3 spines connected. Anything other than 3 is a violation.
where device.platform.vendor == Vendor.CISCO &&
device.platform.deviceType == DeviceType.SWITCH &&
"deviceType:fabric" in device.tagNames &&
length(device.name) >= 10 &&
substring(device.name, 8, 10) == "SL"
let spines = countSpineNeighbours(device)
let violation = length(spines) != 3
let violationReason = if violation
then join(" ", [toString(3 - length(spines)),
"misisng link(s) from spines to leaf",
device.name
else ""
connectedSpines: (foreach spine in spines
select spine.deviceName),
count: length(spines),
violation: length(spines) != 3,
violationReason: violationReason
Extension
Be great to see how this could be extended to identify the missing spines name.
  • May 17, 2024
One option is to find all the spines based on the naming convention - SP in position 8
findAllSpines() =
substring(device.name, 8, 10) == "SP"
select device.name;
The fabric name is in position 2, 6 digits, this aligns across all devices within the fabric.
getMissingSpines(allSpines, fabricName, connectedSpines) =
foreach spine in allSpines
where fabricName == substring(spine, 2, 8) && spine not in connectedSpines
select spine;
and finally adjust the original script to use these functions.
let allSpines = findAllSpines()
device.name
else ""
let connectedSpines = (foreach spine in spines
let fabricName = substring(device.name, 2, 8)
let missingSpines = getMissingSpines(allSpines, fabricName, connectedSpines)
fabricName: fabricName,
missingSpines: missingSpines,
connectedSpines: connectedSpines,
  • May 17, 2024
Other options include putting tags within the source devices, so this can be made simpler.
for example,
  • tag the fabric name
  • tag the device as a leaf or spine
and use this information in the NQE script
